This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Velleman DVM020 Multimeter Battery Replacement
    1. Velleman DVM020 Multimeter Battery Replacement, Turn off the multimeter: step 1, image 1 of 2 Velleman DVM020 Multimeter Battery Replacement, Turn off the multimeter: step 1, image 2 of 2
      • Turn off your multimeter.
      • Unplug the test leads from the measurement jacks of your multimeter.
      Ask FixBot
    2. Velleman DVM020 Multimeter Battery Replacement, Release the edges: step 2, image 1 of 2 Velleman DVM020 Multimeter Battery Replacement, Release the edges: step 2, image 2 of 2
      • Release the edge from the top-left corner.
      • Release the edge from the top-right corner.
      Ask FixBot
    3. Velleman DVM020 Multimeter Battery Replacement, Remove the multimeter: step 3, image 1 of 3 Velleman DVM020 Multimeter Battery Replacement, Remove the multimeter: step 3, image 2 of 3 Velleman DVM020 Multimeter Battery Replacement, Remove the multimeter: step 3, image 3 of 3
      • Press the case to pop the top of the multimeter out.
      • Remove the multimeter.
      Ask FixBot
    1. Velleman DVM020 Multimeter Battery Replacement, Unscrew the cover: step 4, image 1 of 1
      • Flip the multimeter over.
      • Unscrew the screw
      Ask FixBot
    2. Velleman DVM020 Multimeter Battery Replacement, Remove the cover: step 5, image 1 of 3 Velleman DVM020 Multimeter Battery Replacement, Remove the cover: step 5, image 2 of 3 Velleman DVM020 Multimeter Battery Replacement, Remove the cover: step 5, image 3 of 3
      • Lift the tab.
      • Pull the tab up to remove the cover.
      Ask FixBot
    3. Velleman DVM020 Multimeter Battery Replacement, Remove the batteries: step 6, image 1 of 2 Velleman DVM020 Multimeter Battery Replacement, Remove the batteries: step 6, image 2 of 2
      • Remove the batteries by pushing against the spring and pivoting them upward
      • Pay close attention to the orientation for reinstallation!
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Coco
495 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 72
All Time: 186
