VanMoof No 3 Light Battery Replacement
  1. VanMoof No 3 Light Battery Replacement, Battery: step 1, image 1 of 3 VanMoof No 3 Light Battery Replacement, Battery: step 1, image 2 of 3 VanMoof No 3 Light Battery Replacement, Battery: step 1, image 3 of 3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: step 2, image 1 of 1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: step 3, image 1 of 2 VanMoof No 3 Light Battery Replacement, Remove the battery: step 3, image 2 of 2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: step 4, image 1 of 2 VanMoof No 3 Light Battery Replacement, Unsolder the battery: step 4, image 2 of 2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: step 5, image 1 of 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: step 5, image 2 of 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: step 5, image 3 of 3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: step 6, image 1 of 1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: step 7, image 1 of 3 VanMoof No 3 Light Battery Replacement, Reassemble: step 7, image 2 of 3 VanMoof No 3 Light Battery Replacement, Reassemble: step 7, image 3 of 3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: step 8, image 1 of 2 VanMoof No 3 Light Battery Replacement, Reassemble 2: step 8, image 2 of 2
    • Test the light turns on
    • Screw the back plate to the lense.
3 other people completed this guide.
Martin Hampton
1,308 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 153
All Time: 7,802
