Shop the Holiday Gift Guide
Vanmoof No 3 Replacement Mudguards
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
63
All Time:
1,499
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Sounds easy, but you need to modify the new rear mudguard.
The most time consuming step is to buy the mudguards. This sounds easy except
  • Vanmoof don't list the mudguards. Email Vanmoof support and they'll create a special sales link. You need to buy the M2/M3 mudguards which can be made to fit.
  • They only ship to certain countries (why, it’s just postage?). It took 6 months to pick mine up !!
    1. Vanmoof No 3  Replacement Mudguards, Get the Mudguards: step 1, image 1 of 1
      • Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
      Ask FixBot
    2. Vanmoof No 3  Replacement Mudguards, The problem: step 2, image 1 of 1
      • You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
      Ask FixBot
    3. Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: step 3, image 1 of 3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: step 3, image 2 of 3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: step 3, image 3 of 3
      • The rear mudguard will need to be cut at the front.
      • First cut at parallel to the bottom about 16mm long
      • Second cut is 7mm in from the rounded edge
      Ask FixBot
    4. Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: step 4, image 1 of 3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: step 4, image 2 of 3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: step 4, image 3 of 3
      • Bend the edges over so you make a rounded lip
      Ask FixBot
    5. Vanmoof No 3  Replacement Mudguards, Drill the new hole: step 5, image 1 of 1
      • Drill the frame attachment hole
      Ask FixBot
      • Bolt to the frame
      Ask FixBot
Author
with
Martin Hampton
1,350 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 63
All Time: 1,499
