Shop the Holiday Gift Guide
Valiant Automatic Hot Pot Disassembly
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
82
All Time:
563
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Valiant Automatic Hot Pot kettle is super easy to disassemble! You may want to disassemble this device to replace a dead wire or to see an example of a simple circuit.
Tools
    1. Valiant Automatic Hot Pot Disassembly, Valiant Automatic Hot Pot: step 1, image 1 of 3 Valiant Automatic Hot Pot Disassembly, Valiant Automatic Hot Pot: step 1, image 2 of 3 Valiant Automatic Hot Pot Disassembly, Valiant Automatic Hot Pot: step 1, image 3 of 3
      • Turn the kettle upside down and unscrew the bolt on the bottom.
      Ask FixBot
    2. Valiant Automatic Hot Pot Disassembly: step 2, image 1 of 1
      • Open the plastic base to reveal the wires and heating element.
      Ask FixBot
    3. Valiant Automatic Hot Pot Disassembly: step 3, image 1 of 2 Valiant Automatic Hot Pot Disassembly: step 3, image 2 of 2
      • Unclip the gold brackets attached to the wires from the heating element.
      Ask FixBot
    4. Valiant Automatic Hot Pot Disassembly: step 4, image 1 of 3 Valiant Automatic Hot Pot Disassembly: step 4, image 2 of 3 Valiant Automatic Hot Pot Disassembly: step 4, image 3 of 3
      • Remove the bottom bolt attached to the metal bracket.
      • This should be able to be unscrewed by hand, but if it is stuck, a wrench or pliers may be required.
      • Remove the metal bracket from the screw.
      • Fully remove the black plastic base from the heating element.
      Ask FixBot
    5. Valiant Automatic Hot Pot Disassembly: step 5, image 1 of 3 Valiant Automatic Hot Pot Disassembly: step 5, image 2 of 3 Valiant Automatic Hot Pot Disassembly: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the 1 mm screws on each side connecting the metal bracket to the wires.
      Ask FixBot
    6. Valiant Automatic Hot Pot Disassembly: step 6, image 1 of 2 Valiant Automatic Hot Pot Disassembly: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 1 mm screw holding the T bracket together.
      Ask FixBot
    7. Valiant Automatic Hot Pot Disassembly: step 7, image 1 of 2 Valiant Automatic Hot Pot Disassembly: step 7, image 2 of 2
      • Open the bracket and remove the resistor.
      Ask FixBot
    8. Valiant Automatic Hot Pot Disassembly: step 8, image 1 of 1
      • 1 Plastic base with AC plug and insulated wire with gold clip
      • 1 BR210 FC resistor
      • 1 insulated wire with gold clip
      • 1 Metal bracket
      • 2 Bolts
      • 2 Sharp Phillips head screws (attached the wires to the bracket)
      • 1 Flat-bottomed Phillips head screw (held the bracket together)
      • 1 Kettle body with the heating element (metal plate)
      Ask FixBot
    9. Valiant Automatic Hot Pot Disassembly: step 9, image 1 of 1
      • When assembled, the kettle automatically heats when plugged in. The kettle does not stop heating nor does it alert you when the water is boiled.
      Ask FixBot
Author
with
Eli Benatar Faranesh
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 82
All Time: 563
