VTechCS6719-16 Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
71
All Time:
658
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide demonstrates a walk-through of steps needed to completely dismantle the phone in order to locate the screen cover and replace it with a new one.
Tools
    1. VTechCS6719-16 Screen Replacement, Screen: step 1, image 1 of 1
      • Slide the back cover off the cause.
      Ask FixBot
    2. VTechCS6719-16 Screen Replacement: step 2, image 1 of 1
      • Lift the battery.
      • Unplug the two pin cable from the connector.
      Ask FixBot
    3. VTechCS6719-16 Screen Replacement: step 3, image 1 of 1
      • Unscrew the two 10mm screws in phone base.
      Ask FixBot
    4. VTechCS6719-16 Screen Replacement: step 4, image 1 of 1
      • Using the metal spudger gently, but firmly edge along the device .
      • When you feel a hook or latch use a firm but gentle lifting motion upward to unlatch the front and back case.
      Ask FixBot
    5. VTechCS6719-16 Screen Replacement: step 5, image 1 of 1
      • Unscrew a second set of 10mm screws to access to the other side.
      Ask FixBot
    6. VTechCS6719-16 Screen Replacement: step 6, image 1 of 1
      • The front case is now free and able to be manipulated.
      • Set aside the circuit board and back case as they will get in the way.
      Ask FixBot
    7. VTechCS6719-16 Screen Replacement: step 7, image 1 of 1
      • Using a single finger apply a light force on the screen cover to release from the case.
      • Now the old screen can be replaced with a new desired one, simply properly align and it will clip into place.
      Ask FixBot
Charles montes
513 Reputation
5 Guides authored
UMass Dartmouth, Team 5-5, Martin Fall 2016 Member of UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 71
All Time: 658
