Up to 20% off select tools
VTechCS6719-16 Button Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
85
All Time:
706
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
This guide demonstrates a walk-through of steps needed to completely dismantle the phone in order to locate the buttons and replace them with new ones.
    1. VTechCS6719-16 Button Replacement, Buttons: step 1, image 1 of 1
      • Remove the sliding back cover from case.
      Ask FixBot
    2. VTechCS6719-16 Button Replacement: step 2, image 1 of 1
      • lift the battery and unplug the two pin cable from phone base.
      Ask FixBot
    3. VTechCS6719-16 Button Replacement: step 3, image 1 of 1
      • Remove the two 10mm screws at the base of the phone .
      Ask FixBot
    4. VTechCS6719-16 Button Replacement: step 4, image 1 of 1
      • Use the spudger along the edge using a firm but gentle lifting motion.
      • When doing this feel for the hooks that latch the phones front and back cases.
      Ask FixBot
    5. VTechCS6719-16 Button Replacement: step 5, image 1 of 1
      • Unscrew a second set of 10mm screws to obtain access to the other side.
      Ask FixBot
    6. VTechCS6719-16 Button Replacement: step 6, image 1 of 1
      • The front of the phone can now be placed to the side
      • You will notice the button covers, these display the numerical values and positions of each button
      • These can be placed aside as they will get in the way later.
      Ask FixBot
    7. VTechCS6719-16 Button Replacement: step 7, image 1 of 1
      • Now the silicon pads for the phone buttons are exposed.
      • These can easily be removed by pulling away the pads from the circuit board.
      • To replace simply align the new pad onto the button positions.
      Ask FixBot
Author
with
Charles montes
513 Reputation
5 Guides authored
UMass Dartmouth, Team 5-5, Martin Fall 2016 Member of UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 85
All Time: 706
