VTech VM3254 Camera Circuit Board Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. VTech VM3254 Camera Circuit Board Replacement, Camera Circuit Board: step 1, image 1 of 3 VTech VM3254 Camera Circuit Board Replacement, Camera Circuit Board: step 1, image 2 of 3 VTech VM3254 Camera Circuit Board Replacement, Camera Circuit Board: step 1, image 3 of 3
      • Remove the two 8 mm Phillips #00 screws from the back of the device.
      • Use the Jimmy tool to open the case.
      • You may need to use an opening pick to hold it open.
      • Remove the face from the case.
      Ask FixBot
    2. VTech VM3254 Camera Circuit Board Replacement: step 2, image 1 of 2 VTech VM3254 Camera Circuit Board Replacement: step 2, image 2 of 2
      • Remove the three 8 mm Phillips #00 screws from the board.
      • Gently remove the board from the case.
      • Be careful, there are wires connecting the board to the case that could be damaged.
      Ask FixBot
Christina Block
375 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 138
