VTech Kidizoom Smartwatch DX2 Speakers Replacement
  1. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: step 1, image 1 of 2 VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: step 1, image 2 of 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 2, image 1 of 2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 2, image 2 of 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 3, image 1 of 2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 3, image 2 of 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 4, image 1 of 3 VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 4, image 2 of 3 VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 4, image 3 of 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Motherboard: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 6, image 1 of 2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 6, image 2 of 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 7, image 1 of 2 VTech Kidizoom Smartwatch DX2 Speakers Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Speakers: step 8, image 1 of 1
    • Carefully desolder the speaker from the board.
    • Be careful to not desolder the battery cable.
Jessica Richard
515 Reputation
4 Guides authored
1 Guide Comment
hi, where did you buy the spare speaker?
minhhai79 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 965
