VTech Kidizoom Camera Connect Motherboard Replacement
  1. VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: step 1, image 1 of 2 VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: step 1, image 2 of 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Motherboard Replacement: step 2, image 1 of 2 VTech Kidizoom Camera Connect Motherboard Replacement: step 2, image 2 of 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Motherboard Replacement: step 3, image 1 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 3, image 2 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 3, image 3 of 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Motherboard Replacement: step 4, image 1 of 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect Motherboard Replacement: step 6, image 1 of 2 VTech Kidizoom Camera Connect Motherboard Replacement: step 6, image 2 of 2
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect Motherboard Replacement: step 7, image 1 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 7, image 2 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 7, image 3 of 3
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect Motherboard Replacement: step 8, image 1 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 8, image 2 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 8, image 3 of 3
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
Justin Sanchez
520 Reputation
4 Guides authored
USF Tampa, Team 6-4, Eyestone Spring 2016 Member of USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 2,313
