Introduction
A quick guide on how to remove stuck or clean buttons for your VTech InnoTab 2. If you are having trouble with the buttons on your InnoTab 2 feeling stuck or unresponsive follow these steps below.
Apply slight pressure and slide the button above the battery cabinet to the right to open.
Remove battery cabinet cover by sliding away from the center of device.
Remove all nine plastic caps from the back of the device using the plastic opening tool.
Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
