VHS Shell Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
8
Past 7 Days:
53
Past 30 Days:
194
All Time:
4,366
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, you will learn step-by-step instructions on how to replace the broken shell of a VHS tape when it is too broken to work correctly in a VHS player. In doing this repair, you will be able to salvage the tape so that it can be digitized or continue to be watched. No special skills are needed for this repair, with a screwdriver being the only tool used. It is recommended that you cut or rip off any labels on the sides of the tape before beginning, so that it will be easier to take the top half of the shell off.
Tools
    1. VHS Shell Replacement, Plastic Shell: step 1, image 1 of 2 VHS Shell Replacement, Plastic Shell: step 1, image 2 of 2
      • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
      Ask FixBot
    2. VHS Shell Replacement: step 2, image 1 of 1
      • Once the screws are out, pull off the front of the VHS shell.
      • Take off any labels on the sides of tape before doing this step.
      • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
      Ask FixBot
    3. VHS Shell Replacement: step 3, image 1 of 2 VHS Shell Replacement: step 3, image 2 of 2
      • Hold down on the white lever.
      • While holding down, carefully take out the reel on the right.
      • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
      Ask FixBot
    4. VHS Shell Replacement: step 4, image 1 of 2 VHS Shell Replacement: step 4, image 2 of 2
      • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
      • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
      Ask FixBot
    5. VHS Shell Replacement: step 5, image 1 of 1
      • Once the screws are out, pull off the front of the replacement shell.
      Ask FixBot
    6. VHS Shell Replacement: step 6, image 1 of 1
      • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
      • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
      Ask FixBot
    7. VHS Shell Replacement: step 7, image 1 of 1
      • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
      Ask FixBot
    8. VHS Shell Replacement: step 8, image 1 of 1
      • Turn the reels to retract any excess tape hanging out of the top.
      • This isn't a necessary step, just one that I prefer to do.
      Ask FixBot
    9. VHS Shell Replacement: step 9, image 1 of 1
      • Place the top of the replacement shell back on.
      Ask FixBot
    10. VHS Shell Replacement: step 10, image 1 of 1
      • Screw the screws back in with a screwdriver.
      Ask FixBot
2 Guide Comments
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - Reply Share
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. - Reply Share
Past 24 Hours: 8
Past 7 Days: 53
Past 30 Days: 194
All Time: 4,366
