Unowhy SSD replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
106
All Time:
318
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Unowhy SSD replacement, Remove the backplate: step 1, image 1 of 1
      • Remove the 10 PH00 screws from the back of the laptop
      • Do not try to remove them, they are captive screws
      Ask FixBot
    2. Unowhy SSD replacement: step 2, image 1 of 1
      • To separate the backplate from the rest of the laptop, there are two options
      • 1. Use an opening pick and insert it, and try to gently open the laptop with that
      • 2. Use your fingernails (not recommeded, it tried it before)
      Ask FixBot
    3. Ask FixBot
    4. Unowhy SSD replacement: step 4, image 1 of 1
      • Remove the PH00 screw locking the slot
      Ask FixBot
    5. Unowhy SSD replacement: step 5, image 1 of 1
      • Make sure the 4 pin side is on the left (in yellow), and the 5 pin side is on the right (in red)
      • If it isn't in the right side, you can damage your laptop and/or your SSD, so be carefull
      Ask FixBot
    6. Unowhy SSD replacement: step 6, image 1 of 2 Unowhy SSD replacement: step 6, image 2 of 2
      • Then insert the SSD, keep the orientation from before and don't forget to place the screw (2nd picture)
      • Your SSD might have its components on the other side, it can varies from one SSD to another, so don't fully trust my pictures
      Ask FixBot
    7. Unowhy SSD replacement: step 7, image 1 of 1
      • Replug the battery
      Ask FixBot
    8. Unowhy SSD replacement: step 8, image 1 of 1
      • Close the backplate and screw it in place
      Ask FixBot
Enjoy your piece of shi- your unowhy !
Doume20
280 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 106
All Time: 318
