15% Off Selected iFixit Tools — Limited Time
MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement, AirPort Board Assembly: step 1, image 1 of 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
    Ask FixBot
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 2, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 2, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
    Ask FixBot
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 3, image 2 of 2
    • Move the antenna cables aside, clear of the AirPort board.
    Ask FixBot
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 4, image 1 of 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: step 4, image 2 of 2
    • Pull the AirPort board straight out of its socket on the I/O board.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 184
