Macbook Pro Glass Replacement
  1. Macbook Pro Glass  Replacement, Prepare a Workspace: step 1, image 1 of 1
    • Set up a clean workspace and gather all supplies. You will need your Macbook Pro, a new screen, a hair dryer, a screen cleaning cloth, and a suction cup.
  2. Macbook Pro Glass  Replacement, Heat the Edges of the Screen: step 2, image 1 of 2 Macbook Pro Glass  Replacement, Heat the Edges of the Screen: step 2, image 2 of 2
    • Use a hair dryer to heat the adhesive around the edges of the screen you are removing.
  3. Macbook Pro Glass  Replacement, Use suction to remove the Screen: step 3, image 1 of 3 Macbook Pro Glass  Replacement, Use suction to remove the Screen: step 3, image 2 of 3 Macbook Pro Glass  Replacement, Use suction to remove the Screen: step 3, image 3 of 3
    • Attach the suction cup found in the iFixit repair kit to the corner of your screen, by gently pressing down until it seals. Lift screen away by pulling up on the suction cup key ring.
  4. Macbook Pro Glass  Replacement, Preparing for the New Screen: step 4, image 1 of 2 Macbook Pro Glass  Replacement, Preparing for the New Screen: step 4, image 2 of 2
    • Use a screen cleaning cloth to buff out any marks on your Macbook Pros screen surface.
    • Use a screen cleaning cloth to buff out any marks on the inside of new glass that will be applied.
  5. Macbook Pro Glass  Replacement, Preparing Screen Adhesive: step 5, image 1 of 2 Macbook Pro Glass  Replacement, Preparing Screen Adhesive: step 5, image 2 of 2
    • Remove the strips covering the adhesive on the new screen.
    • Heat the new adhesive strips evenly using the hair dryer.
  6. Macbook Pro Glass  Replacement, Applying the New Screen: step 6, image 1 of 2 Macbook Pro Glass  Replacement, Applying the New Screen: step 6, image 2 of 2
    • Place the new screen in position. Confirm that the new screen is properly aligned with the edges of the Macbook Pro.
  7. Macbook Pro Glass  Replacement, Attaching the New Screen: step 7, image 1 of 2 Macbook Pro Glass  Replacement, Attaching the New Screen: step 7, image 2 of 2
    • Using the screen cleaning cloth carefully press the edges of the screen to seal the adhesive.
  8. Macbook Pro Glass  Replacement, Remove Cover: step 8, image 1 of 1
    • Peel the protective covering off the new screen.
  9. Macbook Pro Glass  Replacement, Reheat the Adhesive: step 9, image 1 of 3 Macbook Pro Glass  Replacement, Reheat the Adhesive: step 9, image 2 of 3 Macbook Pro Glass  Replacement, Reheat the Adhesive: step 9, image 3 of 3
    • To insure the seal of the adhesive, reheat it again with the hair drying.
  10. Macbook Pro Glass  Replacement, Final Press: step 10, image 1 of 1
    • Finally, use the screen cleaning cloth and carefully press the edges of the screen one more time.
  11. Macbook Pro Glass  Replacement, You did it!: step 11, image 1 of 1
    • Enjoy your laptop with it's brand new screen!
Akh1913
1,282 Reputation
1 Guide authored
PIRL Gadget Garage Member of PIRL Gadget Garage
Community
9 Members
10 Guides authored
Past 24 Hours: 12
Past 7 Days: 75
Past 30 Days: 447
All Time: 129,800
