Introduction
The following steps show you the basics to opening up the device.
Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
As the gaps open, slide the guitar picks along the sides to separate the panels.
Some close up shots of the seam that you're making sure not to miss internal tabs that hold the back on.
Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
Would love to see more photos on every single location of the snap tabs under the back cover. I don't want to snap any of the tabs off by pulling to hard around these snap tabs.
What is mean when you say by hand? "until they can easily be pried apart by hand." Using your fingers or a tool?
8 other people completed this guide.
