Udreamer Turntable Belt Replacement
  1. Udreamer Turntable Belt Replacement, Belt: step 1, image 1 of 3 Udreamer Turntable Belt Replacement, Belt: step 1, image 2 of 3 Udreamer Turntable Belt Replacement, Belt: step 1, image 3 of 3
    • Gently pull off the retaining clip at the center of the turntable platter.
    • Put it in a safe spot to avoid losing it as you will need it for reassembly.
  2. Udreamer Turntable Belt Replacement: step 2, image 1 of 1
    • Lift the platter straight up and off the spindle to reveal the belt and motor assembly underneath.
  3. Udreamer Turntable Belt Replacement: step 3, image 1 of 1
    • Carefully stretch the old belt off the motor pulley and platter grooves.
    • Inspect the pulley and platter for debris or damage.
  4. Udreamer Turntable Belt Replacement: step 4, image 1 of 2 Udreamer Turntable Belt Replacement: step 4, image 2 of 2
    • Position the new belt around the motor pulley and the inner rim of the platter.
    • Ensure the belt lies flat without twists.
  5. Udreamer Turntable Belt Replacement: step 5, image 1 of 3 Udreamer Turntable Belt Replacement: step 5, image 2 of 3 Udreamer Turntable Belt Replacement: step 5, image 3 of 3
    • Place the platter back onto the spindle, aligning it with the motor assembly.
    • Hold the belt in place as you lower the platter.
  6. Udreamer Turntable Belt Replacement: step 6, image 1 of 3 Udreamer Turntable Belt Replacement: step 6, image 2 of 3 Udreamer Turntable Belt Replacement: step 6, image 3 of 3
    • Press the retaining clip back onto the spindle to secure the platter.
    • Ensure the clip is tightly fastened to prevent the platter from wobbling during use.
Gustavo Deveze
133 Reputation
1 Guide authored
1 Guide Comment
how do i know if the problem is the belt? it seems tight enough (i have no knowledge of this stuff). but it fits snug around the turntable thing but its still slow
liam - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 75
All Time: 1,158
