Roku XD 2050X Remote Motherboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
96
All Time:
1,548
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In this guide, we will show you how to replace the circuit board inside your Roku XD remote control.
Tools
  • Spudger
    4.9
    1. Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: step 1, image 1 of 2 Roku XD 2050X Remote Motherboard Replacement, Remote Control Casing: step 1, image 2 of 2
      • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
      • Remove the battery cover.
      • Remove the two AA batteries.
      Ask FixBot
    2. Roku XD 2050X Remote Motherboard Replacement: step 2, image 1 of 2 Roku XD 2050X Remote Motherboard Replacement: step 2, image 2 of 2
      • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
      • Gently twist the spudger to separate the top and bottom halves of the remote.
      Ask FixBot
    3. Roku XD 2050X Remote Motherboard Replacement: step 3, image 1 of 1
      • Gently use the spudger to pry the circuit board loose.
      Ask FixBot
    4. Roku XD 2050X Remote Motherboard Replacement: step 4, image 1 of 1
      • Using either end of the spudger, gently lift and remove the clear keypad backing.
      Ask FixBot
    5. Roku XD 2050X Remote Motherboard Replacement: step 5, image 1 of 1
      • Using either end of the spudger, lift and remove the rubber keypad.
      Ask FixBot
    1. Roku XD 2050X Remote Motherboard Replacement, Remote Motherboard: step 6, image 1 of 1
      • Now that the remote is disassembled, you simply need to reassemble the remote using the replacement circuit board.
      • Be sure to dispose of the faulty circuit board properly. Recycle if possible!
      Ask FixBot
To reassemble the remote once you've replaced the circuit board, return to the remote control disassembly page and follow the steps in reverse order.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 96
All Time: 1,548
