Asus ROG FX60VM Hard Drive Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
72
All Time:
1,316
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to replace the hard drive from your Asus ROG FX60VM laptop.
The hard drive is a component that stores and retrieves data in your computer. If your hard drive is running low on storage or failing (making irregular noises or constantly crashing), it may be time to replace your hard drive.
However, before you start, make sure you've made a copy of your data so you don’t lose it while you’re doing the replacement. Also be sure to power off your device and unplug from the power outlet before you begin the repair.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Asus ROG FX60VM Hard Drive Replacement, HDD: step 1, image 1 of 2 Asus ROG FX60VM Hard Drive Replacement, HDD: step 1, image 2 of 2
      • Before disassembling the laptop, turn the laptop off and make sure it's unplugged from the power supply.
      Ask FixBot
    2. Asus ROG FX60VM Hard Drive Replacement: step 2, image 1 of 3 Asus ROG FX60VM Hard Drive Replacement: step 2, image 2 of 3 Asus ROG FX60VM Hard Drive Replacement: step 2, image 3 of 3
      • Flip the laptop over so the back case is facing up.
      • Remove the ten 2.5 mm screws from the back case using a Phillips #0 screwdriver.
      • Use a plastic opening tool and picks to pry the back panel off of the device.
      Ask FixBot
    3. Asus ROG FX60VM Hard Drive Replacement: step 3, image 1 of 3 Asus ROG FX60VM Hard Drive Replacement: step 3, image 2 of 3 Asus ROG FX60VM Hard Drive Replacement: step 3, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Put the tip of Halberd spudger under the battery connector and lift it gently to disconnect it from the motherboard.
      • You may need to wiggle the spudger up and down in order to disconnect the battery connector.
      Ask FixBot
    4. Asus ROG FX60VM Hard Drive Replacement: step 4, image 1 of 2 Asus ROG FX60VM Hard Drive Replacement: step 4, image 2 of 2
      • Remove the four 3.0 mm screws from the HDD case using a Phillips #1 screwdriver.
      Ask FixBot
    5. Asus ROG FX60VM Hard Drive Replacement: step 5, image 1 of 3 Asus ROG FX60VM Hard Drive Replacement: step 5, image 2 of 3 Asus ROG FX60VM Hard Drive Replacement: step 5, image 3 of 3
      • Do not lift the HDD up, as you may damage the connector highlighted in red.
      • Hold the back of the HDD , and slide it out of the port to disconnect it from the motherboard.
      Ask FixBot
    6. Asus ROG FX60VM Hard Drive Replacement: step 6, image 1 of 3 Asus ROG FX60VM Hard Drive Replacement: step 6, image 2 of 3 Asus ROG FX60VM Hard Drive Replacement: step 6, image 3 of 3
      • Remove the two 3.0 mm screws on each side of the HDD mounting bracket using a Phillips #1 screwdriver.
      • Lift the HDD out of the mounting bracket, and install a new HDD or SSD to the mounting bracket.
      Ask FixBot
After install a new HDD or SSD, for better performace, initialize the new disk.
JingZhao Liang
163 Reputation
1 Guide authored
1 Guide Comment
Thank you so much JingZhao Liang for the concise and to the point guide. It's easy to follow and I am very impressed that you mentioned how to dispose the e-waste properly in conclusion part.
Tayyaba Riasat - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 72
All Time: 1,316
