SR405QM Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
78
All Time:
1,657
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Follow this guide to remove a dead battery and replace it with a new one.
Tools
    1. SR405QM Battery Replacement, Battery: step 1, image 1 of 1
      • Gently place the instrument upside-down on a soft surface.
      • Locate the battery cavity cap and screws.
      Ask FixBot
    2. SR405QM Battery Replacement: step 2, image 1 of 1
      • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
      Ask FixBot
    3. SR405QM Battery Replacement: step 3, image 1 of 2 SR405QM Battery Replacement: step 3, image 2 of 2
      • Remove the cap by lifting upwards to reveal the battery.
      Ask FixBot
    4. SR405QM Battery Replacement: step 4, image 1 of 3 SR405QM Battery Replacement: step 4, image 2 of 3 SR405QM Battery Replacement: step 4, image 3 of 3
      • Gently lift the battery from the cavity.
      • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order with a fresh battery.
2 other people completed this guide.
Chris Pittner
220 Reputation
7 Guides authored
Cal Poly, Team 5-18, Forte Winter 2013 Member of Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 78
All Time: 1,657
