Introduction
This guide will show how the motherboard of the UE Boom 2 Bluetooth speaker is removed. This is an extensive and intrusive process which removes all components of the speaker.
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Remove the rubber stripping using a metal spudger.
Work around the edge of the rubber stripping slowly prying up the edge.
On the bottom, unscrew the four 15mm Phillips Head #2 screws, using a Phillips head #2 screwdriver.
Pry up at the location marked, and remove the plastic end cap
Now on the top, unscrew the four 15 mm Phillips Head #2 screws, using a Phillips Head #2 screwdriver.
Using the metal spudger, pry up the plastic cap at the point marked and remove the cap.
Carefully un-loop the cable with a plastic opening tool or spudger and unplug it from motherboard.
Pull out the battery, and handle with care.
Using the metal spudger, pry up the plastic tab on the inside.
Pry up around the entire inside circumference.
Repeat on the other end.
Using the metal spudger tool, pry up the inside edge of the mesh lining.
Working down the strip on both sides. Careful as to not rip the mesh.
Unscrew the two 5 mm Phillips head #1 screws, using a Phillips Head #1 screwdriver.
Using the metal spudger, pry open the edge of the cover.
Using the metal spudger, pry the plastic casing up.
Repeat on the other side of the speaker.
Using the metal spudger, specifically the pointy end, find the gap between the speaker and the passive radiator (the larger rectangular speaker-like-object next to the speaker).
Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
Once one end is out, use your fingers to gently pull off completely so as not to bend the wire too aggressively.
Using the metal spudger, work it under the passive radiator.
Work the passive radiator up around all edges, and pull out of casing.
With the passive radiator removed, pry up the pink rubber seal using a metal spudger.
Remove using fingers.
Using the metal spudger, work it under the edge of the speaker.
Work around the speaker on all sides.
With both the speaker and passive radiator removed from one side of the Boom 2, repeat steps 13-18 for the other side.
Using angled tweezers, pull up the black sheath on tan connector port.
Gently pull the white ribbon cable out from connector.
Confirm that all cables from speakers, Bluetooth antenna, and battery have been disconnected from the motherboard.
Grab the single piece of green motherboard that runs perpendicular to the motherboard, and pull out of casing.
