UE BOOM 2 Motherboard Replacement
  1. UE BOOM 2 Motherboard Replacement, Motherboard: step 1, image 1 of 2 UE BOOM 2 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Motherboard Replacement: step 2, image 1 of 2 UE BOOM 2 Motherboard Replacement: step 2, image 2 of 2
    • Remove the rubber port cover, peeling up from one end.
  3. UE BOOM 2 Motherboard Replacement: step 3, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 3, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 3, image 3 of 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Motherboard Replacement: step 4, image 1 of 1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Motherboard Replacement: step 5, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 5, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 5, image 3 of 3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using a Phillips head #2 screwdriver.
    • Pry up at the location marked, and remove the plastic end cap
  6. UE BOOM 2 Motherboard Replacement: step 6, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 6, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 6, image 3 of 3
    • Now on the top, unscrew the four 15 mm Phillips Head #2 screws, using a Phillips Head #2 screwdriver.
    • Using the metal spudger, pry up the plastic cap at the point marked and remove the cap.
  7. UE BOOM 2 Motherboard Replacement: step 7, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 7, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 7, image 3 of 3
    • Carefully un-loop the cable with a plastic opening tool or spudger and unplug it from motherboard.
    • Pull out the battery, and handle with care.
  8. UE BOOM 2 Motherboard Replacement: step 8, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 8, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 8, image 3 of 3
    • Using the metal spudger, pry up the plastic tab on the inside.
    • Pry up around the entire inside circumference.
    • Repeat on the other end.
  9. UE BOOM 2 Motherboard Replacement: step 9, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 9, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 9, image 3 of 3
    • Using the metal spudger tool, pry up the inside edge of the mesh lining.
    • Working down the strip on both sides. Careful as to not rip the mesh.
  10. UE BOOM 2 Motherboard Replacement: step 10, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 10, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 10, image 3 of 3
    • Unscrew the two 5 mm Phillips head #1 screws, using a Phillips Head #1 screwdriver.
    • Using the metal spudger, pry open the edge of the cover.
  11. UE BOOM 2 Motherboard Replacement: step 11, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 11, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 11, image 3 of 3
    • Using the metal spudger, pry the plastic casing up.
    • Repeat on the other side of the speaker.
  12. UE BOOM 2 Motherboard Replacement: step 12, image 1 of 2 UE BOOM 2 Motherboard Replacement: step 12, image 2 of 2
    • Pull each cover off.
  13. UE BOOM 2 Motherboard Replacement: step 13, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 13, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 13, image 3 of 3
    • Using the metal spudger, specifically the pointy end, find the gap between the speaker and billow (the larger rectangular speaker-like-object next to the speaker).
    • Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
    • Once one end is out, use your fingers to gently pull off completely so as not to bend the wire too aggressively.
  14. UE BOOM 2 Motherboard Replacement: step 14, image 1 of 1
    • Repeat previous process for other side of the speaker and billow (boxed).
  15. UE BOOM 2 Motherboard Replacement: step 15, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 15, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 15, image 3 of 3
    • Using the metal spudger, work it under the billow.
    • Work the billow up around all edges, and pull out of casing.
  16. UE BOOM 2 Motherboard Replacement: step 16, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 16, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 16, image 3 of 3
    • With the billow removed, pry up the pink rubber seal using a metal spudger.
    • Remove using fingers.
    • Do not use excessive force with the metal spudger, doing so could cut the seal.
  17. UE BOOM 2 Motherboard Replacement: step 17, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 17, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 17, image 3 of 3
    • Using the metal spudger, work it under the edge of the speaker.
    • Work around the speaker on all sides.
    • Pull up slowly as there is a cable attached to the motherboard.
  18. UE BOOM 2 Motherboard Replacement: step 18, image 1 of 2 UE BOOM 2 Motherboard Replacement: step 18, image 2 of 2
    • Once speaker is detached from casing, remove cable from motherboard.
  19. UE BOOM 2 Motherboard Replacement: step 19, image 1 of 2 UE BOOM 2 Motherboard Replacement: step 19, image 2 of 2
    • Now, both the billow and speaker have been removed from one side of the Boom 2, repeat steps 13-18 for the other side.
  20. UE BOOM 2 Motherboard Replacement: step 20, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 20, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 20, image 3 of 3
    • Using angled tweezers, pull up the black sheath on tan connector port.
    • Gently pull the white ribbon cable out from connector.
  21. UE BOOM 2 Motherboard Replacement: step 21, image 1 of 2 UE BOOM 2 Motherboard Replacement: step 21, image 2 of 2
    • With the ribbon cable disconnected from the motherboard, remove the bluetooth antennae.
  22. UE BOOM 2 Motherboard Replacement: step 22, image 1 of 3 UE BOOM 2 Motherboard Replacement: step 22, image 2 of 3 UE BOOM 2 Motherboard Replacement: step 22, image 3 of 3
    • Confirm that all cables from speakers, Bluetooth antenna, and battery have been disconnected from the motherboard.
    • Grab the single piece of green motherboard that runs perpendicular to the motherboard, and pull out of casing.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 66
All Time: 6,196
