Introduction
Removing the drone cover is the only way to access many of the inner components of the U818A.
Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
Step two is disconnecting and removing the head lamp.
Use a screw driver to remove the 5mm screw. Remove head lamp of drone.
Disconnect the electronics from the frame of the drone by pulling each arm out of the hole in the frame holding it in place.
If present, remove the white tape over the black and red wires for the head lamp with a metal spudger (a wide flat-head tool for separating plastic parts).
Separate the plastic tabs securing the motor arms to the drone cover and delicately pull out the arm. Do this for all 4 arms to remove the frame from the cover.
