Shop the Holiday Gift Guide
Twentieth Anniversary Mac Teardown
Views: 14K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
129
All Time:
13,892
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Community-Contributed Guide
Tools
    1. Twentieth Anniversary Mac Teardown, Logic Board: step 1, image 1 of 1
      • Use the release tabs to remove the rear cover
      Ask FixBot
    2. Twentieth Anniversary Mac Teardown: step 2, image 1 of 1
      • Remove any ComSlot II or PCI cards that may be installed and their risers.
      Ask FixBot
    3. Twentieth Anniversary Mac Teardown: step 3, image 1 of 1
      • Unplug the logic board connections to the PRAM battery and fan.
      • Remove the PRAM battery from it's Velcro mounting.
      • Remove the four #0 Philips screws securing the hard drive and processor fan assembly.
      • Remove the hard drive and processor fan assembly.
      Ask FixBot
    4. Twentieth Anniversary Mac Teardown: step 4, image 1 of 1
      • Remove the two T6 Torx screws securing the A/V input board.
      • Remove the A/V Input board
      Ask FixBot
    5. Twentieth Anniversary Mac Teardown: step 5, image 1 of 1
      • Remove the white plastic shield
      • Remove the T6 torx screw securing the logic board to the frame.
      Ask FixBot
    6. Twentieth Anniversary Mac Teardown: step 6, image 1 of 2 Twentieth Anniversary Mac Teardown: step 6, image 2 of 2
      • Turn the TAM around with the front facing you.
      • Use a spudger to gently loosen the speaker covers from their press-fit snaps. Remove the speaker covers.
      Ask FixBot
    7. Twentieth Anniversary Mac Teardown: step 7, image 1 of 1
      • Remove the six T8 torx screws securing the front case to the rear case.
      Ask FixBot
    8. Twentieth Anniversary Mac Teardown: step 8, image 1 of 3 Twentieth Anniversary Mac Teardown: step 8, image 2 of 3 Twentieth Anniversary Mac Teardown: step 8, image 3 of 3
      • Gently pull the tabs toward the center to release the latches hold the front and back together. These tabs are fragile but release easily. Use caution.
      • Lean the top forward and lift up to pull the front case from it's bottom latches.
      • DO NOT TRY TO REMOVE THE FRONT CASE. It is still connected to the back case by several wires and cables.
      Ask FixBot
    9. Twentieth Anniversary Mac Teardown: step 9, image 1 of 3 Twentieth Anniversary Mac Teardown: step 9, image 2 of 3 Twentieth Anniversary Mac Teardown: step 9, image 3 of 3
      • Disconnect the pink and white backlight inverter cable and the black and white right speaker cable from behind the floppy disk drive on the right side.
      • On the left side, disconnect the 50-pin SCSI ribbon cable, analog audio cable and power cable from the CD-ROM drive.
      • Disconnect the black and white left speaker cable.
      • Disconnect the flat, orange display data cable.
      • Open the top case to the left like a book. There will be one more 50-pin cable to disconnect from the front control panel board.
      Ask FixBot
    10. Twentieth Anniversary Mac Teardown: step 10, image 1 of 1
      • The easiest method to remove the logic board is to remove it with the tuner card and cabling.
      • Disconnect the five cables illustrated.
      Ask FixBot
    11. Twentieth Anniversary Mac Teardown: step 11, image 1 of 1
      • Remove the T10 torx screw and extract the stiff wire cable brace from the left side
      Ask FixBot
    12. Twentieth Anniversary Mac Teardown: step 12, image 1 of 1
      • Carefully peel back the tape securing the cables to the white, plastic logic board cover. Pull the cables back to reveal the back side of the logic board.
      • Remove the five T10 screws holding the logic and tuner boards to the back case.
      Ask FixBot
    13. Twentieth Anniversary Mac Teardown: step 13, image 1 of 3 Twentieth Anniversary Mac Teardown: step 13, image 2 of 3 Twentieth Anniversary Mac Teardown: step 13, image 3 of 3
      • Lift the logic board from the left edge then straight up to remove it from the rear case.
      • The logic board slides out of the cabling connector.
      Ask FixBot
7 other people completed this guide.
Author
with
Dylan
511 Reputation
1 Guide authored
4 Guide Comments
Hi,
One of the member of my Forum is looking for the Bose subwoofer including the power cable. Have you an idee on where could he find it ?
Thx.
Raziel
vitalisfrance - Reply Share
It's missing the step to remove the two torx screws on the upper back side, below the cover with all the holes, after Step 5
Deagol - Reply Share
Dose anybody know what goes in the top-most chip slot that is empty? Is that for an L2 Cache chip?
garo211 - Reply Share
To echo the comment from 2014, i just performed this guide and there is a critical step missing between steps 6 & 7. The small plastic grille at the top rear needs to be removed; There are two tabs at the bottom and two on the sides. Flex it to remove. Then remove the two visible torx screws to release the top.
coryheisterkamp - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 129
All Time: 13,892
