Turtle Beach Stealth Ultra Back Plate Replacement
    1. Turtle Beach Stealth Ultra Back Plate Replacement, Back Plate: step 1, image 1 of 2 Turtle Beach Stealth Ultra Back Plate Replacement, Back Plate: step 1, image 2 of 2
      • Use tweezers to pull out rubber pieces in front of the screws.
      Ask FixBot
    2. Turtle Beach Stealth Ultra Back Plate Replacement: step 2, image 1 of 2 Turtle Beach Stealth Ultra Back Plate Replacement: step 2, image 2 of 2
      • Remove the 10 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Turtle Beach Stealth Ultra Back Plate Replacement: step 3, image 1 of 2 Turtle Beach Stealth Ultra Back Plate Replacement: step 3, image 2 of 2
      • Remove the sticker on the back of the plate.
      • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
      Ask FixBot
    4. Turtle Beach Stealth Ultra Back Plate Replacement: step 4, image 1 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 4, image 2 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 4, image 3 of 3
      • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
      • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
      • Be cautious not to break the LCD screen while you move the opening tool around.
      Ask FixBot
    5. Turtle Beach Stealth Ultra Back Plate Replacement: step 5, image 1 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 5, image 2 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 5, image 3 of 3
      • Use an opening tool to detach the front plate from the back.
      • You may need to work the opening tool all the way around the seam between the two plates.
      Ask FixBot
Dominic Dodge
856 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 90
All Time: 446
