Introduction
If the headset does not turn on ( after charging it for hours ) you might have to replace the battery with a newer one. Some ways to check if your headset doesn't not turn on is if the light next to the power button does not turn on or if the microphone doesn't make any sound. You will have to be careful when taking the headset apart because there are many wires attached to the cover and since any excessive force can damage the device. The device should be turned off and at low battery as well to ensure maximum safety and to work away from liquids.
