Turtle Beach Pure Air Button Microswitch Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
64
All Time:
265
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to access and identify the left and right click microswitches in the Turtle Beach Pure Air White wireless RGB gaming mouse (Model TBM-1102-15). These motherboard-mounted switches register button presses—if they wear out or fail, clicks may not register, may register inconsistently, or may “double-click.” If your mouse buttons aren’t responding, review Turtle Beach Pure Air Buttons Not Registering Input for symptom checks first. This guide focuses on locating the microswitches and related components; microswitch replacement requires desoldering and soldering on the motherboard.
    1. Turtle Beach Pure Air Button Microswitch Replacement, Bottom Cover: step 1, image 1 of 2 Turtle Beach Pure Air Button Microswitch Replacement, Bottom Cover: step 1, image 2 of 2
      • Power off the mouse by moving the power switch to the center.
      Ask FixBot
    2. Turtle Beach Pure Air Button Microswitch Replacement: step 2, image 1 of 2 Turtle Beach Pure Air Button Microswitch Replacement: step 2, image 2 of 2
      • Peel back the mouse feet.
      • Remove the three 1.6mm screws using a JIS #000 screwdriver.
      • Remove the single 1.6mm screws using remove using a 1.3 mm hex screwdriver.
      Ask FixBot
    3. Turtle Beach Pure Air Button Microswitch Replacement: step 3, image 1 of 2 Turtle Beach Pure Air Button Microswitch Replacement: step 3, image 2 of 2
      • Carefully remove the bottom cover of the mouse.
      • Be cautious of the cable connecting the bottom cover to the rest of the mouse.
      Ask FixBot
    4. Turtle Beach Pure Air Button Microswitch Replacement: step 4, image 1 of 3 Turtle Beach Pure Air Button Microswitch Replacement: step 4, image 2 of 3 Turtle Beach Pure Air Button Microswitch Replacement: step 4, image 3 of 3
      • Disconnect the ribbon cable securing the upper shell to the motherboard.
      • Lift the locking clip to release the cable from its connector.
      Ask FixBot
    1. Turtle Beach Pure Air Button Microswitch Replacement, Motherboard: step 5, image 1 of 3 Turtle Beach Pure Air Button Microswitch Replacement, Motherboard: step 5, image 2 of 3 Turtle Beach Pure Air Button Microswitch Replacement, Motherboard: step 5, image 3 of 3
      • Carefully disconnect the battery clip from the motherboard socket by softly pulling the bottom of the clip.
      Ask FixBot
    2. Turtle Beach Pure Air Button Microswitch Replacement: step 6, image 1 of 2 Turtle Beach Pure Air Button Microswitch Replacement: step 6, image 2 of 2
      • Remove the two 1.6 mm screws on the middle left and lower right sides with a JIS000 screwdriver to disconnect the motherboard from the lower shell.
      Ask FixBot
    3. Turtle Beach Pure Air Button Microswitch Replacement: step 7, image 1 of 2 Turtle Beach Pure Air Button Microswitch Replacement: step 7, image 2 of 2
      • Gently lift the motherboard out of the housing.
      Ask FixBot
    1. Turtle Beach Pure Air Button Microswitch Replacement, Scroll Wheel: step 8, image 1 of 3 Turtle Beach Pure Air Button Microswitch Replacement, Scroll Wheel: step 8, image 2 of 3 Turtle Beach Pure Air Button Microswitch Replacement, Scroll Wheel: step 8, image 3 of 3
      • Pull the scroll wheel out of its mounting.
      Ask FixBot
    1. Turtle Beach Pure Air Button Microswitch Replacement, Button Microswitch: step 9, image 1 of 2 Turtle Beach Pure Air Button Microswitch Replacement, Button Microswitch: step 9, image 2 of 2
      • Carefully lift the motherboard to expose the rear side of the board, including the microswitch solder joints.
      • Desolder the solder joints of the microswitch.
      Ask FixBot
This guide is rated Moderate for disassembly. Replacing the microswitch itself requires soldering and is recommended only for users with advanced repair experience.To reassemble your device, follow these instructions in reverse order.
Malachi Davis
245 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 64
All Time: 265
