Turtle Beach Pure Air Battery Replacement
    1. Turtle Beach Pure Air Battery Replacement, Bottom Cover: step 1, image 1 of 2 Turtle Beach Pure Air Battery Replacement, Bottom Cover: step 1, image 2 of 2
      • Power off the mouse by moving the power switch to the center.
      Ask FixBot
    2. Turtle Beach Pure Air Battery Replacement: step 2, image 1 of 2 Turtle Beach Pure Air Battery Replacement: step 2, image 2 of 2
      • Peel back the mouse feet.
      • Remove the three 1.6mm screws using a JIS #000 screwdriver.
      • Remove the single 1.6mm screws using remove using a 1.3 mm hex screwdriver.
      Ask FixBot
    3. Turtle Beach Pure Air Battery Replacement: step 3, image 1 of 2 Turtle Beach Pure Air Battery Replacement: step 3, image 2 of 2
      • Carefully remove the bottom cover of the mouse.
      • Be cautious of the cable connecting the bottom cover to the rest of the mouse.
      Ask FixBot
    4. Turtle Beach Pure Air Battery Replacement: step 4, image 1 of 3 Turtle Beach Pure Air Battery Replacement: step 4, image 2 of 3 Turtle Beach Pure Air Battery Replacement: step 4, image 3 of 3
      • Disconnect the ribbon cable securing the upper shell to the motherboard.
      • Lift the locking clip to release the cable from its connector.
      Ask FixBot
    1. Turtle Beach Pure Air Battery Replacement, Motherboard: step 5, image 1 of 3 Turtle Beach Pure Air Battery Replacement, Motherboard: step 5, image 2 of 3 Turtle Beach Pure Air Battery Replacement, Motherboard: step 5, image 3 of 3
      • Carefully disconnect the battery clip from the motherboard socket by softly pulling the bottom of the clip.
      Ask FixBot
    2. Turtle Beach Pure Air Battery Replacement: step 6, image 1 of 2 Turtle Beach Pure Air Battery Replacement: step 6, image 2 of 2
      • Remove the two 1.6 mm screws on the middle left and lower right sides with a JIS000 screwdriver to disconnect the motherboard from the lower shell.
      Ask FixBot
    3. Turtle Beach Pure Air Battery Replacement: step 7, image 1 of 2 Turtle Beach Pure Air Battery Replacement: step 7, image 2 of 2
      • Gently lift the motherboard out of the housing.
      Ask FixBot
    1. Turtle Beach Pure Air Battery Replacement, Battery: step 8, image 1 of 3 Turtle Beach Pure Air Battery Replacement, Battery: step 8, image 2 of 3 Turtle Beach Pure Air Battery Replacement, Battery: step 8, image 3 of 3
      • Carefully pry up the battery.
      • Prying the battery may take a bit of force since it is glued to the plastic.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 56
All Time: 258
