Turtle Beach Ear Force XO One Adapter Buttons Replacement
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: step 1, image 1 of 1
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 2, image 1 of 1
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 3, image 1 of 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 3, image 2 of 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 3, image 3 of 3
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 4, image 1 of 1
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
Joseph Lane
128 Reputation
1 Guide authored
UMass Dartmouth, Team 3-1, Shastany Fall 2015 Member of UMass Dartmouth, Team 3-1, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G1
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,569
