Turntable Needle Replacement and Calibration
    1. Turntable Needle Replacement and Calibration, Needle: step 1, image 1 of 3 Turntable Needle Replacement and Calibration, Needle: step 1, image 2 of 3 Turntable Needle Replacement and Calibration, Needle: step 1, image 3 of 3
      • Begin with an Audio-Technica AT-LP120XUSB-SV Manual Turntable, with the tonearm placed in the tonearm holder off to the side.
      • Twist the metal ring at the end of stylus (needle) cartridge counterclockwise.
      • After the metal ring is twisted, there should be a space between metal ring and stylus cartridge.
      Ask FixBot
    2. Turntable Needle Replacement and Calibration: step 2, image 1 of 3 Turntable Needle Replacement and Calibration: step 2, image 2 of 3 Turntable Needle Replacement and Calibration: step 2, image 3 of 3
      • Pull the stylus cartridge away from the tonearm.
      • Flip the cartridge on its back, so the underside is exposed.
      Ask FixBot
    3. Turntable Needle Replacement and Calibration: step 3, image 1 of 2 Turntable Needle Replacement and Calibration: step 3, image 2 of 2
      • Pull the green stylus holder away from the cartridge.
      • If the stylus is bent, you can either bend it in place to straighten it, or you can replace the stylus.
      Ask FixBot
    4. Turntable Needle Replacement and Calibration: step 4, image 1 of 1
      • Once the stylus has either been straightened or replaced, place the green cover back onto the cartridge and push down until it "clicks" in place.
      Ask FixBot
    5. Turntable Needle Replacement and Calibration: step 5, image 1 of 1
      Ask FixBot
    6. Turntable Needle Replacement and Calibration: step 6, image 1 of 3 Turntable Needle Replacement and Calibration: step 6, image 2 of 3 Turntable Needle Replacement and Calibration: step 6, image 3 of 3
      • Place the stylus on the dot in the center of the "A lines", furthest away from the center of the record.
      • Check to see if the edge of stylus cartridge is aligned with the "B lines" on the protractor.
      • When the edge of the stylus cartridge is not aligned with the "B lines" on the protractor, this means it is out of alignment and needs to be calibrated. To begin, make sure that the tonearm is in the lifted position, by lifting the tonearm lever.
      Ask FixBot
    7. Turntable Needle Replacement and Calibration: step 7, image 1 of 3 Turntable Needle Replacement and Calibration: step 7, image 2 of 3 Turntable Needle Replacement and Calibration: step 7, image 3 of 3
      • Hold the cartridge in place, and use the screwdriver to unscrew the screws on top of the cartridge.
      • Once the cartridge is loose, slide the screws and check alignment to see if the stylus box lines up with the "B lines".
      • Once the cartridge lines up with the "B lines", use the screwdriver to secure the screws in place.
      Ask FixBot
Leah Lloyd
146 Reputation
1 Guide authored
UW Tacoma, Team S1-G12, Cardinal Spring 2020 Member of UW Tacoma, Team S1-G12, Cardinal Spring 2020
UWT-CARDINAL-S20S1G12
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 53
All Time: 4,894
