Tungsten E full teardown
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Tungsten E full teardown, Teardown: step 1, image 1 of 2 Tungsten E full teardown, Teardown: step 1, image 2 of 2
    • There are 4 torx screws in each corner. Undo them and take than out.
  2. Tungsten E full teardown: step 2, image 1 of 3 Tungsten E full teardown: step 2, image 2 of 3 Tungsten E full teardown: step 2, image 3 of 3
    • Slide a spudger in between the metal casing. Slide it all around the casing, releasing the back from the clips holding it in.
  3. Tungsten E full teardown: step 3, image 1 of 1
    • Prise up the case, using the spudger.
  4. Tungsten E full teardown: step 4, image 1 of 3 Tungsten E full teardown: step 4, image 2 of 3 Tungsten E full teardown: step 4, image 3 of 3
    • The Lcd connector is held in with a double lock connector, simply push the locks forward, and the cable will disconnect with the help if a spudger.
fscottcopeland
214 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 117
