Tuck Lock Clasp Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
61
Past 30 Days:
150
All Time:
691
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your backpack/bag tuck lock clasp is broken, missing, or unable to lock your bag, use this guide to replace the tuck lock clasp.
Before using this guide, inspect there is any small buildup or dust at the tuck lock clasp, which may affect use; it can be removed using pointed tweezers or small brush. Be sure to test the tuck lock a few times to make sure it is not stuck.
Tools
    1. Tuck Lock Clasp Replacement, Tuck Lock Clasp: step 1, image 1 of 1
      • Locate broken tuck lock clasp.
      Ask FixBot
    2. Tuck Lock Clasp Replacement: step 2, image 1 of 3 Tuck Lock Clasp Replacement: step 2, image 2 of 3 Tuck Lock Clasp Replacement: step 2, image 3 of 3
      • Grab the broken clasp and flip it so that you can see the heads of the screws.
      Ask FixBot
    3. Tuck Lock Clasp Replacement: step 3, image 1 of 2 Tuck Lock Clasp Replacement: step 3, image 2 of 2
      • Using a Phillips screwdriver, remove the screws.
      Ask FixBot
    4. Tuck Lock Clasp Replacement: step 4, image 1 of 2 Tuck Lock Clasp Replacement: step 4, image 2 of 2
      • Place one hand holding on to the strap and another grabbing the clasp.
      • Pull the strap and clasp away from each other until completely separated.
      Ask FixBot
    5. Tuck Lock Clasp Replacement: step 5, image 1 of 3 Tuck Lock Clasp Replacement: step 5, image 2 of 3 Tuck Lock Clasp Replacement: step 5, image 3 of 3
      • Push the new clasp onto the strap.
      • Ensure that the screw holes of the strap and clasp are lined up with each other.
      Ask FixBot
    6. Tuck Lock Clasp Replacement: step 6, image 1 of 3 Tuck Lock Clasp Replacement: step 6, image 2 of 3 Tuck Lock Clasp Replacement: step 6, image 3 of 3
      • Reinsert the screws into the holes.
      Ask FixBot
    7. Tuck Lock Clasp Replacement: step 7, image 1 of 2 Tuck Lock Clasp Replacement: step 7, image 2 of 2
      • Tighten the screws using a Phillips screwdriver.
      Ask FixBot
    8. Tuck Lock Clasp Replacement: step 8, image 1 of 1
      • Your tuck lock clasp has now been replaced!
      Ask FixBot
    9. Tuck Lock Clasp Replacement: step 9, image 1 of 3 Tuck Lock Clasp Replacement: step 9, image 2 of 3 Tuck Lock Clasp Replacement: step 9, image 3 of 3
      • Ensure your replacement tuck lock clasp works by inserting the tuck lock clasp into the base plate.
      Ask FixBot
Finish Line
Dawson V
169 Reputation
1 Guide authored
UC Davis, Team 2-7, Morris Fall 2025 Member of UC Davis, Team 2-7, Morris Fall 2025
UCD-MORRIS-F25S2G7
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 61
Past 30 Days: 150
All Time: 691
