Truma Combi 4 Recirculating Air Fan Wheel Repair
    1. Truma Combi 4 Recirculating Air Fan Wheel Repair, Preparing the Lid: step 1, image 1 of 1
      • slide the cover slightly upwards
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Repair, hebe den Deckel nach vorne aus der Schiene: step 2, image 1 of 3 Truma Combi 4 Recirculating Air Fan Wheel Repair, hebe den Deckel nach vorne aus der Schiene: step 2, image 2 of 3 Truma Combi 4 Recirculating Air Fan Wheel Repair, hebe den Deckel nach vorne aus der Schiene: step 2, image 3 of 3
      • lift the cover forwards out of the rail
      • pay attention to the detents / tabs on the rail
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Housing Screws: step 3, image 1 of 1
      • remove the four screws with the Torx 20 screwdriver
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Cover: step 4, image 1 of 3 Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Cover: step 4, image 2 of 3 Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Cover: step 4, image 3 of 3
      • lift the cover forwards over the connections
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Screws: step 5, image 1 of 1
      • remove the four screws of the cover with the Torx 20 screwdriver
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the cover: step 6, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the cover: step 6, image 2 of 2
      • lift the cover away from the fan wheel
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Repair, Positioning the Fan Whee: step 7, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Repair, Positioning the Fan Whee: step 7, image 2 of 2
      • Position the fan wheel by turning it so that, ...
      • ... that the hole in the fan wheel is facing upwards
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Repair, Loosening the Allen Screw: step 8, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Repair, Loosening the Allen Screw: step 8, image 2 of 2
      • The screw locks the wheel onto the motor shaft and only needs to be loosened, not completely removed!
      • Now, loosen the Allen screw with the 2mm Allen key.
      • Loosen the screw using the long end as a lever.
      • loosen (do not remove!) the screw from above until the wheel can be pulled off the motor shaft without any problems
      Ask FixBot
    3. Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Fan Wheel: step 9, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Repair, Removing the Fan Wheel: step 9, image 2 of 2
      • Pull the wheel straight off the motor shaft.
      Ask FixBot
To reassemble your device, folloe the steps in reverse order.
Special thanks to these translators:
de en
100%
hainzy is helping us fix the world! Want to contribute?
Start translating ›
hainzy
10,972 Reputation
47 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 39
Past 30 Days: 114
All Time: 1,602
