Truma Combi 4 Recirculating Air Cover Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
96
All Time:
835
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, I'll show you how to remove the recirculating air cover of the Truma Combi 4.
    1. Truma Combi 4 Recirculating Air Cover Disassembly, Preparing the Lid: step 1, image 1 of 1
      • slide the cover slightly upwards
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Cover Disassembly, hebe den Deckel nach vorne aus der Schiene: step 2, image 1 of 3 Truma Combi 4 Recirculating Air Cover Disassembly, hebe den Deckel nach vorne aus der Schiene: step 2, image 2 of 3 Truma Combi 4 Recirculating Air Cover Disassembly, hebe den Deckel nach vorne aus der Schiene: step 2, image 3 of 3
      • lift the cover forwards out of the rail
      • pay attention to the detents / tabs on the rail
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Cover Disassembly, Removing the Housing Screws: step 3, image 1 of 1
      • remove the four screws with the Torx 20 screwdriver
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Cover Disassembly, Removing the Cover: step 4, image 1 of 3 Truma Combi 4 Recirculating Air Cover Disassembly, Removing the Cover: step 4, image 2 of 3 Truma Combi 4 Recirculating Air Cover Disassembly, Removing the Cover: step 4, image 3 of 3
      • lift the cover forwards over the connections
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Cover Disassembly, Removing the Screws: step 5, image 1 of 1
      • remove the four screws of the cover with the Torx 20 screwdriver
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Cover Disassembly, Removing the cover: step 6, image 1 of 2 Truma Combi 4 Recirculating Air Cover Disassembly, Removing the cover: step 6, image 2 of 2
      • lift the cover away from the fan wheel
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
de en
100%
hainzy is helping us fix the world! Want to contribute?
Start translating ›
hainzy
11,341 Reputation
50 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 96
All Time: 835
