Shop the Holiday Gift Guide
Trim a Webbing Belt
Views: 3.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
49
Past 30 Days:
209
All Time:
3,514
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Trim a Webbing Belt
Introduction
Go to step 1 ↓
If a Patagonia webbing belt is too long or starting to fray, it can be easily fixed. This guide will demonstrate how to trim the belt and seal the edge using a hot knife or scissors and a lighter.
Before beginning, make sure to read through the entire guide and gather the necessary tools and materials. The hot knife method is recommended for professional repair technicians with access to this equipment and alternative instructions for completing the repair without a hot knife are provided in Step 6.
Let’s get fixing!
Return to the Patagonia Care & Repair homepage.
Tools
    1. Trim a Webbing Belt, Turn on the hot knife: step 1, image 1 of 1
      • Turn on the hot knife to allow it time to heat up.
      • Alert those working nearby that the hot knife is on.
      • Melting plastic on the hot knife causes noxious fumes. Turn it on only while using it, and only use it in a well-ventilated area or outside.
      Ask FixBot
    2. Trim a Webbing Belt, Mark the correct size: step 2, image 1 of 1
      • Put on and fasten the belt into a pair of pants in the same manner it will be worn.
      • Use chalk or a heat-erasable pen to mark the new end of the belt.
      • Remove the belt for cutting.
      Ask FixBot
    3. Trim a Webbing Belt, Draw the tip design: step 3, image 1 of 3 Trim a Webbing Belt, Draw the tip design: step 3, image 2 of 3 Trim a Webbing Belt, Draw the tip design: step 3, image 3 of 3
      • There are three standard tip designs with different aesthetics and functionality:
      • 45 Degree or Point - This tip design is the easiest to feed through a buckle, but has the highest likelihood of fraying in the future.
      • Square End - This tip design is the least likely to fray.
      • Corners Cut - This is a hybrid of the point and square designs.
      • Draw the desired tip design at the mark made in Step 2 with chalk or a heat-erasable pen.
      Ask FixBot
      • Use a scrap piece of webbing to test that the hot knife has come up to temperature. The knife should easily melt through the webbing.
      • Holding the belt tight from both ends, carefully cut on the marked line.
      • Use a pair of pliers to hold the webbing if the mark is close to the end.
      • Save or discard the removed webbing responsibly.
      • Allow the belt to fully cool before handling.
      • Turn off the hot knife and alert those working nearby that the knife is off but still hot.
      Ask FixBot
      • If needed, use a lighter to melt and soften the melted edge on both sides until it has the desired smoothness.
      • Allow the belt to fully cool.
      • This method can also be used to repair any future fraying.
      Ask FixBot
    4. Trim a Webbing Belt, Alternative method: step 6, image 1 of 3 Trim a Webbing Belt, Alternative method: step 6, image 2 of 3 Trim a Webbing Belt, Alternative method: step 6, image 3 of 3
      • To shorten a webbing belt without a hot knife:
      • Follow the marking instructions in Steps 2 and 3.
      • Cut along the line with a pair of sharp scissors.
      • Then use the technique in Step 5 to melt the cut edge until it's fully encased and no frayed pieces remain.
      Ask FixBot
Finish Line
Author
with
Zach Mueller
1,810 Reputation
9 Guides authored
Patagonia Member of Patagonia
Community
9 Members
384 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 49
Past 30 Days: 209
All Time: 3,514
