Trek 820 Spokes Replacement
  1. Trek 820 Spokes Replacement, Front Wheel: step 1, image 1 of 2 Trek 820 Spokes Replacement, Front Wheel: step 1, image 2 of 2
    • Facing your bike, straddle your front wheel between your knees.
    • Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
    • Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
  2. Trek 820 Spokes Replacement: step 2, image 1 of 2 Trek 820 Spokes Replacement: step 2, image 2 of 2
    • With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand.
    • The brake will now be open wide enough to permit removal of the wheel.
  3. Trek 820 Spokes Replacement: step 3, image 1 of 2 Trek 820 Spokes Replacement: step 3, image 2 of 2
    • Find the quick release lever on the outside of the bike's fork on the right hand side. Flip the lever down and turn the lever counter clockwise, loosening the lever until it comes off.
  4. Trek 820 Spokes Replacement: step 4, image 1 of 1
    • After the quick release lever is removed, the wheel can be separated from the front fork.
    • In reassembling the wheel to the bike, perform the steps in reverse order.
    • With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
    • Squeeze the brake calipers together and return the cable noodle back into the holder.
    • Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
  5. Trek 820 Spokes Replacement, Tire: step 6, image 1 of 1
    • Locate the valve stem and remove the valve stem cap if one is present.
  6. Trek 820 Spokes Replacement: step 7, image 1 of 1
    • Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
    • Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
  7. Trek 820 Spokes Replacement: step 8, image 1 of 2 Trek 820 Spokes Replacement: step 8, image 2 of 2
    • Insert the flathead screwdriver, or another sturdy, long object, between the edge of the tire and the wheel rim.
    • Be careful not to damage the inner tube when inserting and moving the screwdriver or other tool. The inner tube is fragile and may be pinched between the wheel rim and tool.
    • Work the edge of the tire out of the wheel rim using a screwdriver, pulling the edge of the tire away from the center of the wheel and out of the rim.
  8. Trek 820 Spokes Replacement: step 9, image 1 of 3 Trek 820 Spokes Replacement: step 9, image 2 of 3 Trek 820 Spokes Replacement: step 9, image 3 of 3
    • Continue around the wheel rim until the whole tire is free from the rim. Now you may separate the tire from the wheel.
    • Be careful not to damage the valve stem as you pull the tire and inner tube off of the wheel rim together.
  9. Trek 820 Spokes Replacement: step 10, image 1 of 2 Trek 820 Spokes Replacement: step 10, image 2 of 2
    • Remove the inner tube from the tire by simply pulling it from the tire carcass.
  10. Trek 820 Spokes Replacement, Spokes: step 11, image 1 of 2 Trek 820 Spokes Replacement, Spokes: step 11, image 2 of 2
    • Make sure you have removed the tires as shown in the prerequisite guides.
    • Slowly peel back the layer of rubber that covers the 32 screws on the tire .
  11. Trek 820 Spokes Replacement: step 12, image 1 of 3 Trek 820 Spokes Replacement: step 12, image 2 of 3 Trek 820 Spokes Replacement: step 12, image 3 of 3
    • You will need a flathead screwdriver
    • You will need to alternate between steps #2 and #3 because the spokes have to be removed one at a time.
    • Remove the screw using the flathead.
    • All screws will be the same size.
    • Only remove the screws of the spokes you are replacing.
  12. Trek 820 Spokes Replacement: step 13, image 1 of 3 Trek 820 Spokes Replacement: step 13, image 2 of 3 Trek 820 Spokes Replacement: step 13, image 3 of 3
    • Once a screw is removed gently remove the spoke from the rim of the tire if it did not fall out.
    • Maneuver the spoke so that it is perpendicular then slide the spoke out.
  13. Trek 820 Spokes Replacement: step 14, image 1 of 1
    • Insert the new spoke into the missing hole.
    • If you are replacing multiple spoke , you will need to alternate between steps #4, and #5 . The spokes must be replaced one at a time.
  14. Trek 820 Spokes Replacement: step 15, image 1 of 1
    • Use the flat head screw driver to insert a screw to stop the spoke from falling out.
Kaveh Karimiyanha
813 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 2,234
