Treblab HD77 Motherboard Replacement
    1. Treblab HD77 Motherboard Replacement, Surround: step 1, image 1 of 3 Treblab HD77 Motherboard Replacement, Surround: step 1, image 2 of 3 Treblab HD77 Motherboard Replacement, Surround: step 1, image 3 of 3
      • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
      Ask FixBot
    2. Treblab HD77 Motherboard Replacement: step 2, image 1 of 3 Treblab HD77 Motherboard Replacement: step 2, image 2 of 3 Treblab HD77 Motherboard Replacement: step 2, image 3 of 3
      • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
      • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
      Ask FixBot
    3. Treblab HD77 Motherboard Replacement: step 3, image 1 of 3 Treblab HD77 Motherboard Replacement: step 3, image 2 of 3 Treblab HD77 Motherboard Replacement: step 3, image 3 of 3
      • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
      • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
      • There is a layer of adhesive between the surround and the plastic housing it is resting on.
      Ask FixBot
    1. Treblab HD77 Motherboard Replacement, LED Light: step 4, image 1 of 3 Treblab HD77 Motherboard Replacement, LED Light: step 4, image 2 of 3 Treblab HD77 Motherboard Replacement, LED Light: step 4, image 3 of 3
      • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
      • There are four points where adhesive is used to hold the LED light strip down.
      • Lift up the LED light strip from the plastic casing.
      Ask FixBot
    2. Treblab HD77 Motherboard Replacement: step 5, image 1 of 3 Treblab HD77 Motherboard Replacement: step 5, image 2 of 3 Treblab HD77 Motherboard Replacement: step 5, image 3 of 3
      • Flip the LED light strip upside down to see where the cord is plugged in.
      • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
      • The cord is very thin and lightweight so use caution when handling.
      Ask FixBot
    1. Treblab HD77 Motherboard Replacement, Motherboard: step 6, image 1 of 3 Treblab HD77 Motherboard Replacement, Motherboard: step 6, image 2 of 3 Treblab HD77 Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Using a Phillips #0 screwdriver, remove all four 10mm screws that were exposed by removing the LED light strip.
      • Lift the plastic ring once all the screws have been removed.
      • The screws are very tiny and can fall inside the device if they are not handled carefully.
      • Repeat steps 1-6 for the opposite side.
      Ask FixBot
    2. Treblab HD77 Motherboard Replacement: step 7, image 1 of 2 Treblab HD77 Motherboard Replacement: step 7, image 2 of 2
      • Slide the inner electronics casing out from the outer tubing encasing it.
      Ask FixBot
    3. Treblab HD77 Motherboard Replacement: step 8, image 1 of 2 Treblab HD77 Motherboard Replacement: step 8, image 2 of 2
      • Unscrew the six 10mm screws holding the two halves of the electronics casing together using a Phillips #0 screwdriver.
      Ask FixBot
    4. Treblab HD77 Motherboard Replacement: step 9, image 1 of 3 Treblab HD77 Motherboard Replacement: step 9, image 2 of 3 Treblab HD77 Motherboard Replacement: step 9, image 3 of 3
      • Insert the blade of an Xacto knife in between the edge of the rubber button cover and the extruded edges holding it in place.
      • Gently trace around the edge until you feel the cover beginning to loosen, and then slowly peel the cover up.
      • Be careful to not apply too much pressure with the blade, as there is a circuit board directly underneath the cover. There is also a layer of strong adhesive between the circuit board and the cover.
      Ask FixBot
    5. Treblab HD77 Motherboard Replacement: step 10, image 1 of 2 Treblab HD77 Motherboard Replacement: step 10, image 2 of 2
      • Using a Phillips #0 screwdriver, unscrew the six 5mm screws holding the circuit board in place.
      Ask FixBot
    6. Treblab HD77 Motherboard Replacement: step 11, image 1 of 2 Treblab HD77 Motherboard Replacement: step 11, image 2 of 2
      • Turn the speaker over to the side with the charging port dock, and gently pull the two halves apart by firmly grasping each half until they separate.
      Ask FixBot
    7. Treblab HD77 Motherboard Replacement: step 12, image 1 of 3 Treblab HD77 Motherboard Replacement: step 12, image 2 of 3 Treblab HD77 Motherboard Replacement: step 12, image 3 of 3
      • Pinch the wire connecting the circuit board to the motherboard between your thumb and pointer finger, and gently remove the wire from the circuit board.
      Ask FixBot
    8. Treblab HD77 Motherboard Replacement: step 13, image 1 of 3 Treblab HD77 Motherboard Replacement: step 13, image 2 of 3 Treblab HD77 Motherboard Replacement: step 13, image 3 of 3
      • Orient the speaker so the motherboard is on the bottom half, facing up, and the circuit board cutout is facing you.
      • Using your thumb and pointer finger grip the plug connected to the large red and black wires at the top just below the extruded lip, and gently lift until the plug comes out.
      Ask FixBot
    9. Treblab HD77 Motherboard Replacement: step 14, image 1 of 3 Treblab HD77 Motherboard Replacement: step 14, image 2 of 3 Treblab HD77 Motherboard Replacement: step 14, image 3 of 3
      • Using your thumb and pointer finger grip the plug connected to the small red and black wires at the top just below the extruded lip, and gently lift until the plug comes out.
      Ask FixBot
    10. Treblab HD77 Motherboard Replacement: step 15, image 1 of 3 Treblab HD77 Motherboard Replacement: step 15, image 2 of 3 Treblab HD77 Motherboard Replacement: step 15, image 3 of 3
      • Take each half of the speaker and unscrew the four, 5mm screws that hold in each diaphragm, using a Phillips #0 screwdriver.
      • Only remove the diaphragm on the side with the motherboard.
      Ask FixBot
    11. Treblab HD77 Motherboard Replacement: step 16, image 1 of 2 Treblab HD77 Motherboard Replacement: step 16, image 2 of 2
      • Using a Phillips #0 screwdriver, unscrew all six 5mm screws on the motherboard.
      Ask FixBot
    12. Treblab HD77 Motherboard Replacement: step 17, image 1 of 2 Treblab HD77 Motherboard Replacement: step 17, image 2 of 2
      • After completing steps 10 and 11, the diaphragm and motherboard should both be loose and free to move.
      • Let the diaphragm hang out of the bottom from its hole and lift the motherboard out of its place.
      Ask FixBot
    13. Treblab HD77 Motherboard Replacement: step 18, image 1 of 3 Treblab HD77 Motherboard Replacement: step 18, image 2 of 3 Treblab HD77 Motherboard Replacement: step 18, image 3 of 3
      • Using your pointer finger and thumb, pinch the top of the plug for the diaphragm from the top just under the extruded lip, and gently lift it up until it unplugs.
      Ask FixBot
    14. Treblab HD77 Motherboard Replacement: step 19, image 1 of 1
      • Use a pair of flush cutters to cut the wire connecting the two diaphragms so the motherboard can be removed.
      • To reassemble, solder the new motherboard to the diaphragm wire.
      Ask FixBot
Hunter Figueiredo
229 Reputation
1 Guide authored
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 Member of UMass Dartmouth, Team 3-5, Biswokarma Fall 2025
UMASSD-BISWOKARMA-F25S3G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 83
All Time: 343
