Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Trackpad prerequisite without reassembly bullet.
Use a T5 Torx driver to remove the ten 5.7 mm screws securing the trackpad assembly:
Swing the screen open slightly, but keep the MacBook upside-down. The trackpad should separate and lay flat on the display.
Carefully feed the trackpad's ribbon cable through its slot in the frame.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
