Introduction
2018 Toyota Yaris car key battery replacement.
Requires a CR2025 3V battery
Tools: Knife or small flat blade screwdriver
Release latch on back of key and pull from key ring to remove the backup metal key from the rest of the fob.
Using a knife or small flat blade screwdriver pry open the two halves of the key.
To avoid cosmetic damage start from the inside where the metal key was removed in the previous step.
Remove black circular cover, underneath is an O-ring and the battery.
Battery can easily be removed and replaced. Using CR2025 3V battery, ensure writing is visible with battery installed.
To reassemble reverse steps, install battery cover, snap the two halves together and push metal key back into its receptacle (no tools required for reassembly).
