Sony DVP-SR200P Processing Board Replacement
  1. Sony DVP-SR200P Processing Board Replacement, Top Cover: step 1, image 1 of 2 Sony DVP-SR200P Processing Board Replacement, Top Cover: step 1, image 2 of 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Processing Board Replacement: step 2, image 1 of 2 Sony DVP-SR200P Processing Board Replacement: step 2, image 2 of 2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Processing Board Replacement, Processing Board: step 3, image 1 of 1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Processing Board Replacement: step 4, image 1 of 2 Sony DVP-SR200P Processing Board Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Processing Board Replacement: step 5, image 1 of 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Processing Board Replacement: step 6, image 1 of 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
Brian Hua
80 Reputation
3 Guides authored
Cal Poly, Team 5-17, Forte Winter 2013 Member of Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Members
6 Guides authored
2 Comments
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - Reply
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,788
