Touchpad with Spacers Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Touchpad with Spacers Removal, Remove the Touchpad Module: step 1, image 1 of 3 Touchpad with Spacers Removal, Remove the Touchpad Module: step 1, image 2 of 3 Touchpad with Spacers Removal, Remove the Touchpad Module: step 1, image 3 of 3
      • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
      • If you're having trouble, check if the Input Module latches are properly unlocked.
      • Lift the Touchpad Module and remove it.
      Ask FixBot
Alex Diaz-Kokaisl
250,336 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 69
