Toshiba Satellite Radius P55W-B5220 Battery Replacement
  1. Toshiba Satellite Radius P55W-B5220 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 Battery Replacement: step 2, image 1 of 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Battery Replacement: step 3, image 1 of 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Battery Replacement: step 4, image 1 of 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 Battery Replacement, Battery: step 5, image 1 of 2 Toshiba Satellite Radius P55W-B5220 Battery Replacement, Battery: step 5, image 2 of 2
    • Remove the four M2x2.5mm P0 Philips head screws.
  6. Toshiba Satellite Radius P55W-B5220 Battery Replacement: step 6, image 1 of 2 Toshiba Satellite Radius P55W-B5220 Battery Replacement: step 6, image 2 of 2
    • Pinch the attached cables and carefully pull away to remove the battery.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 8
All Time: 2,771
