Toshiba Satellite M45 Motherboard Replacement
  1. Toshiba Satellite M45 Motherboard Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Make sure device is off and power supply is disconnected.
    • Flip the laptop to the bottom side.
    • Locate and slide the two battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
  2. Toshiba Satellite M45 Motherboard Replacement, RAM: step 2, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, RAM: step 2, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, RAM: step 2, image 3 of 3
    • Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
    • Then, use a the blue iFixit Opening Tool to pry the cover panel off.
    • Push on to the RAM tabs to disconnect the RAM form the device.
    • The RAM will pop off from the socket. Gently pull the RAM out of the socket.
  3. Toshiba Satellite M45 Motherboard Replacement, Wi-Fi Card: step 3, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, Wi-Fi Card: step 3, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, Wi-Fi Card: step 3, image 3 of 3
    • Use the #1 Phillips head screwdriver to unscrew the panel.
    • Disconnect the black and white wires.
    • Push on the tabs to disconnect the Wi-Fi card.
    • Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
  4. Toshiba Satellite M45 Motherboard Replacement, Hard Drive: step 4, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, Hard Drive: step 4, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, Hard Drive: step 4, image 3 of 3
    • Use the #1 Phillips head screwdriver as to remove the hard drive screw.
    • Use the blue iFixit Opening Tool to pry the cover off.
    • Use the plastic flap to pull the hard drive out of its slot.
  5. Toshiba Satellite M45 Motherboard Replacement, Optical Drive: step 5, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, Optical Drive: step 5, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, Optical Drive: step 5, image 3 of 3
    • Use the #1 Phillips head screwdriver remove the Optical Drive screw.
    • Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
    • Use your hands to pull the rest of the Optical Drive out.
  6. Toshiba Satellite M45 Motherboard Replacement, Keyboard: step 6, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, Keyboard: step 6, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, Keyboard: step 6, image 3 of 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  7. Toshiba Satellite M45 Motherboard Replacement: step 7, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement: step 7, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement: step 7, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  8. Toshiba Satellite M45 Motherboard Replacement, Motherboard: step 8, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement, Motherboard: step 8, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement, Motherboard: step 8, image 3 of 3
    • Disconnect the video cable near the left speaker slowly but firmly pulling upwards.
    • Disconnect the brown ribbon that is located directly in the middle of where the keyboard one was away from the connector.
    • Disconnect the 2-other white ribbons located near the top right half of the keyboard section pulling firmly away from the connector.
  9. Toshiba Satellite M45 Motherboard Replacement: step 9, image 1 of 2 Toshiba Satellite M45 Motherboard Replacement: step 9, image 2 of 2
    • Unscrew all the screws labeled using a micro-screwdriver turning counterclockwise.
    • There are 3-additional screws that need to be removed through the 3-holes located in the optical drive.
  10. Toshiba Satellite M45 Motherboard Replacement: step 10, image 1 of 3 Toshiba Satellite M45 Motherboard Replacement: step 10, image 2 of 3 Toshiba Satellite M45 Motherboard Replacement: step 10, image 3 of 3
    • Using a flat-edge tool begin to pry away the case apart and slowly pulling upward as there is a white ribbon that need to be removed.
    • Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it.
  11. Toshiba Satellite M45 Motherboard Replacement: step 11, image 1 of 2 Toshiba Satellite M45 Motherboard Replacement: step 11, image 2 of 2
    • Now lift out the motherboard. Be careful not to rip any of the pieces out, just wiggle them out.
Nick
127 Reputation
2 Guides authored
Cal Poly, Team 10-42, Garner Spring 2010 Member of Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 19,526
