Toshiba Satellite M45 Battery Replacement
  1. Toshiba Satellite M45 Battery Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite M45 Battery Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite M45 Battery Replacement, Battery: step 1, image 3 of 3
    • If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer.
    • Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components.
    • Locate and slide the 2-battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
Stephen
370 Reputation
3 Guides authored
Cal Poly, Team 10-42, Garner Spring 2010 Member of Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 4,206
