Toshiba Satellite E45t-A4300 Battery Replacement
  1. Toshiba Satellite E45t-A4300 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45t-A4300 Battery Replacement: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45t-A4300 Battery Replacement, Battery: step 3, image 1 of 1
    • Remove the single screw that is near the battery using the same screwdriver.
  4. Toshiba Satellite E45t-A4300 Battery Replacement: step 4, image 1 of 1
    • Disconnect the cord from the motherboard.
  5. Toshiba Satellite E45t-A4300 Battery Replacement: step 5, image 1 of 2 Toshiba Satellite E45t-A4300 Battery Replacement: step 5, image 2 of 2
    • Remove the battery from the laptop.
Jose Marques
433 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 33
All Time: 2,343
