Toshiba Satellite E45T-A4300 SSD Replacement Guide
  1. Toshiba Satellite E45T-A4300  SSD Replacement Guide, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300  SSD Replacement Guide: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300  SSD Replacement Guide, SSD: step 3, image 1 of 2 Toshiba Satellite E45T-A4300  SSD Replacement Guide, SSD: step 3, image 2 of 2
    • Remove the single 3 mm black screw using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300  SSD Replacement Guide: step 4, image 1 of 1
    • Pull the SSD away from the motherboard.
James Nguyen
573 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,030
