Toshiba Satellite E45T-A4300 Heat Sink Replacement
  1. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Heat Sink: step 3, image 1 of 1
    • Remove three 5 mm screws
  4. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 4, image 1 of 3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 4, image 2 of 3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 4, image 3 of 3
    • Pry the heat sink away from the laptop with two hands at both ends.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
James Nguyen
573 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 234
