Toshiba Satellite C655D-S5200 Motherboard Replacement
    • With the battery side facing you, first move the right locking latch to the right.
    • Afterwards, move the left spring latch to the left, but keep your finger there, and pull the battery out with your other hand.
  1. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive cover: step 2, image 1 of 1
    • Remove the single screw securing the hard drive cover to the base.
  2. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive caddy: step 3, image 1 of 1
    • Remove the single screw securing the hard drive caddy to the base.
  3. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive from caddy: step 4, image 1 of 1
    • This step is unnecessary if you're just removing the hard drive for testing purposes, or to replace the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
    • You're done!
  4. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove some screws: step 5, image 1 of 1
    • Remove the twelve "F6"/M2.5x6 screws.
    • Remove the two "F2" screws under where the battery was.
    • Remove the "F3" screw securing the optical drive, and slide the optical drive out.
    • Remove the two "F2" screws from where the optical drive faceplate was.
    • Remove the memory cover screw, pull the memory door open, and remove the two "F6"/M2.5x6 screws from underneath.
    • Use your fingernail or a spudget to get under the keyboard trim, and pry it up. Go along the keyboard trim, pulling it up.
  5. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove keyboard: step 7, image 1 of 2 Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove keyboard: step 7, image 2 of 2
    • Remove the four screws securing the keyboard to the palmrest.
    • Lift the keyboard at the top a little, and pull the keyboard towards the screen, so that you see the locking connector below the keyboard.
    • Push the locking connector's lock towards the screen at both the left and the right points, very gently.
    • Pull the now-loose keyboard cable out of the connector.
  6. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove palmrest cables & palmrest: step 8, image 1 of 1
    • Remove the three palmrest cables from the motherboard, that being the power button cable, the speaker cable, and the touchpad cable.
    • No need to remove any of the other cables yet.
    • Use a spudger to separate the palmrest from the base.
  7. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove fan: step 9, image 1 of 1
    • Remove the fan cable.
    • Remove the two silver-colored fan screws.
    • Remove the single black-colored fan screw.
  8. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove motherboard: step 10, image 1 of 1
    • Remove the single screw securing the motherboard to the base.
    • Remove the two wireless antenna connectors.
    • Remove the LCD cable.
    • Lift the motherboard out of the base.
  9. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove the heatsink: step 11, image 1 of 1
    • Remove the four screws securing the heatsink to the motherboard.
    • Remove the processor, memory, and optionally, the clock battery. Install the first two in the replacement motherboard. You're done!
Joseph Sctbunio
7,332 Reputation
42 Guides authored
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 33
All Time: 2,723
