Introduction
You may want to proceed with this replacement guide if your computer will no longer turn on after charging or if your battery is dying much quicker than normally.
For this replacement guide, please make sure you do not touch the contacts on the battery, as may cause build up of particles on the contacts preventing proper connection. Also check to make sure the computer is not just out of battery life before attempting this replacement. If you do not feel confident with replacing the battery yourself please find someone that can help you with the process.
Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
