Introduction
Before beginning this guide please review Main Battery Replacement, and take out battery to assure there is no power running to the device.
This guide may be required if the computer is failing to boot into Windows or if you need more space to store files. Before replacing the drive please make sure you have a drive to put into the computer and that it is compatible with the components within the laptop (can be found on the manufacture’s website.)
Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
