Toshiba Satellite A75-S226 Wi-Fi Card Replacement
  1. Toshiba Satellite A75-S226 Wi-Fi Card Replacement, Wi-Fi/Memory Cover: step 1, image 1 of 2 Toshiba Satellite A75-S226 Wi-Fi Card Replacement, Wi-Fi/Memory Cover: step 1, image 2 of 2
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  2. Toshiba Satellite A75-S226 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Lift up the cover panel using a plastic opening tool.
  3. Toshiba Satellite A75-S226 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 2 Toshiba Satellite A75-S226 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 2
    • Remove the 5.64 mm screw from the bottom of the crossing bar.
    • Remove the crossing bar.
  4. Toshiba Satellite A75-S226 Wi-Fi Card Replacement: step 4, image 1 of 2 Toshiba Satellite A75-S226 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
  5. Toshiba Satellite A75-S226 Wi-Fi Card Replacement: step 5, image 1 of 2 Toshiba Satellite A75-S226 Wi-Fi Card Replacement: step 5, image 2 of 2
    • Use fingers to push the clips away from memory card.
  6. Toshiba Satellite A75-S226 Wi-Fi Card Replacement: step 6, image 1 of 1
    • Use fingers to remove the Wi-Fi card.
Garrett Gudgel
763 Reputation
13 Guides authored
Cal Poly, Team 4-43, Amido Fall 2010 Member of Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Members
39 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 3,225
